DI 4.0 question
Old Oct 19, 2010 | 02:36 AM
1Ranger75's Avatar
Default DI 4.0 question
I ask this over on the general disscussion board, but I never got an answer. What is the difference between the 4.0 motor in the DI's and the 4.0 in the DII's? Thanks.
Ranger
Old Oct 19, 2010 | 08:08 AM
Long Haul's Avatar
D1 have a GEMS motor and the D11 has a Bosch motor. the block is the same its the intake and fuel injection thats different
Old Oct 19, 2010 | 08:12 AM
okdiscoguy's Avatar
The front cover and timing set are different, but yeah, mostly the intake and sensors
Old Oct 19, 2010 | 08:40 PM
1Ranger75's Avatar
Then why is it that the DII's have all the head gasket problems but the DI's don't? If the differences are only with the injection system and sensors it doesn't make sense.
Old Oct 19, 2010 | 08:46 PM
Its because of the coolant that DII's come from the factory with.
http://www.sancarlosradiator.com/dex-cool_pics.htm
http://www.consumeraffairs.com/autom...m_dexcool.html
Dex-Cool is corrosive and it eats gaskets if it is not properly maintained.
You must check the Ph balance of it once a year and adjust the Ph as needed.
Is it best in my opinion to just do a complete coolant flush and then use any all aluminum safe coolant you want.
I prefer Peak Global.
Old Oct 19, 2010 | 09:03 PM
1Ranger75's Avatar
Thanks for the answers. I was thinking it was some type of mechanical problem.
Old Oct 20, 2010 | 08:44 AM
okdiscoguy's Avatar
D1's had just as many problems as the D2. They failed about 60K. They have all been fixed by now. It was caused by the composition of the gaskets.
Dexcool is only corrosive if it comes into contact with atmosphere, like when you have a leak.
Old Oct 20, 2010 | 05:47 PM
No they dont, they do have head gasket problems but nowhere even close to DII's and Freelanders, both came with Dex-Cool both blow head gaskets like clockwork in the 60-70k range.
Throttle body heaters on DII's leak constantly, DI's dont.
The biggest cooling problem on a DI is the radiator becoming clogged because the owner is not servicing the cooling system often enough.
My head gaskets are original.
Old Oct 20, 2010 | 09:11 PM
discomedic4's Avatar
As are mine.
Old Oct 20, 2010 | 09:42 PM
Danny Lee 97 Disco's Avatar
I think mine are as well.
colemtd
Mar 30, 2019 08:57 PM
