diff lock
Old Mar 23, 2011 | 12:41 PM
Danny Lee 97 Disco's Avatar
Yes all the DI's have it. But if it was rarely used, it most likely is "frozen" as the linkages aare exposed to all the road grime and off-road muck from below as there are not enclosed or shielded well and they are rather puny and nowhere near as sturdy as you would expect before you see it.
If you want to see it in detail take a look at the photo albums linked in my signature. Once you work your way thru it completely it should shift
"Smooth as Butta" as my friend Rob says. He has torn down several, I did mine all alone after finding some good write-ups on other forums and sites. Rover's Noth Forum has a good one and all the parts you need as well as an excellent illustrated parts breakdown with prices of each and everry part you may need.
If you try to force it without tearing into it, you usually create much more damage to fix when you do tear it apart. It's up to you, have fun with it.
Old Mar 23, 2011 | 05:57 PM
If you want to know what can happen when you don't understand the diff lock and get it stuck ask our young friend Calebbo how much it cost him when he tried getting unstuck by rocking between forward and reverse. Seems he blew up some parts in his drivetrain.
Old May 4, 2011 | 08:15 PM
coldstart's Avatar
now I see But I never see a light on the dash telling me it is locked ,I guess the light may be burned out , does the light come on pre ignition when all the other lights are on thanks
Old May 4, 2011 | 08:38 PM
No it does not. There is a switch on the transfer case that grounds that light when the yoke inside the T/C slips over to lock the diff, it depresses a plunger on the CDL switch. If this switch is bad (as mine was as well) the light will never come on.
Old May 4, 2011 | 08:47 PM
adigerol77's Avatar
Just got my "new" '97 D1 3 weeks ago and have not tried the CDL. I know the PO did go off-road, the rear suspension is pretty banged up. Just not sure if they ever engaged the CDL, I've heard you can sometimes engage but if it's not been used it'll stay there. Is there something to feel for when trying to engage to know if it's bad or not?
Old May 4, 2011 | 10:26 PM
KingKong8247's Avatar
You will not be able to move the diff lock lever to the left at all. When I got my truck it was frozen. I could move it forward into low gear but not to the left.
Danny Lee already answered your question by the way:
Old Jul 12, 2011 | 04:34 PM
Wittefish's Avatar
7th Gear
Freeing the diff lock isn't too hard. Search the forums and find instructions. Follow instructions in RAVE manual to remover center console. I had to remove my shift mechanism to get some penetrating oil in there and tap with a drift. Spray and tap, spray and tap. Eventually the rod moved, and now my diff lock works fan-freakin-tastic.
cornbreadj
Dec 27, 2014 07:50 PM
dusty1
Dec 7, 2014 01:57 PM
garover
May 8, 2009 10:33 AM
Disco2Guy
Jun 20, 2008 10:13 PM
Acer
Feb 25, 2005 10:29 PM
