Disco 1 Climate control back lighting not working
Old Feb 24, 2026 | 11:19 PM
Gee's Avatar
Gee
4th Gear
Default Disco 1 Climate control back lighting not working
Can someone advise how to replace this bulb that illuminates the climate controls on my disco 1. Th tried pulling will pliers but does not want to come out. Worried I will break something. Is there a trick to it. Can't find any references in manual.
Appreciate any help
Old Feb 25, 2026 | 08:09 AM
WaltNYC's Avatar
https://landroverforums.com/forum/di...01/#post627251
search function is helpful
Old Feb 25, 2026 | 08:24 AM
disco96sd's Avatar
if it is original bulb after 30 years they can be tight - hit it with a little electrical contact spray and it should wiggle out - just went through this myself
Old Feb 25, 2026 | 10:09 PM
JohnZo's Avatar
The two above come out with 1/4 turn CCW. Looks like the little bugger below might be clipped into the gray plastic holder, to illuminate the fan switch numbers.
Old Feb 25, 2026 | 10:45 PM
Gee's Avatar
Gee
4th Gear
Thanks, it pulls straight out, needed a little spray lube it was stuck hard.
AUH
Sep 11, 2021 10:45 AM
Sean Winter
Aug 26, 2017 12:14 AM
showbet
Sights N Sounds
Mar 7, 2009 07:36 PM
SantaCruzRoverGirl
Jan 18, 2009 06:59 PM
