disco 1 left rear running light not functioning.
Old 03-11-2018, 01:21 AM
pierson100's Avatar
Angry disco 1 left rear running light not functioning.
My 1995 discovery 1 has been having an issue with its left brake light, running light and the additional running light in the bumber. It is only the left side. I fixed the brake light problem ( it was a fuse), but the running light on that side is still not working. I checked all the bulbs and contacts and they are in perfect condition. I have no clue what the issue could be. I also checked to see if it was that weird thing where the glove box light would short out the lights, and that light is fine. Any info is appreciated.
Old 03-11-2018, 07:40 AM
ihscouts's Avatar
There is a ground lug on the left side "D" pillar, level with the window sill. There will be several black wires since that is also a splice location. Check that, it's behind the speakers trim panel. Corrosion, separated lug, broken wires, etc....
Old 03-12-2018, 01:35 PM
pierson100's Avatar
thanks a lot, ill check it out.
deer4011
10-22-2017 11:52 AM
anzesq
03-26-2014 01:45 PM
2ndRR
03-14-2014 05:03 PM
ciocc
12-03-2011 09:15 AM
mrbowenz
05-18-2010 05:12 AM
Quick Reply: disco 1 left rear running light not functioning.
