Disco I Freeze Frame Data/Misfire help
Old Nov 29, 2012 | 06:57 PM
BluePointDisco's Avatar
Default Disco I Freeze Frame Data/Misfire help
I may be dense, but I cannot find a reference to decode the Freeze Frame Data. I am trying to track down a misfire at Idle problem, and these codes came up using my Faultmate MSV2. No clue what the Freeze Frame data means, and I couldn't find a reference in the Rave, this forum or Google search.
THE GEMS FAULT CODE MEMORY CONTAINS CODES FOR THE FOLLOWING FAULTS -:
P0307, CYLINDER 7 MISFIRE DETECTED. P0300, RANDOM/MULTIPLE CYLINDER MISFIRE DETECTED. P0305, CYLINDER 5 MISFIRE DETECTED. P1316, MISFIRE CAUSING EXCESS EMISSIONS.
FREEZE FRAME DATA STORED WAS: 48,6B,E8,42,02,00,03,07,E9
Thanks for your help guys
Old Nov 29, 2012 | 07:48 PM
Here's the GEMS book with the codes and how they are computed.
File Type: pdf
Old Nov 29, 2012 | 08:25 PM
Freeze frame data just means it freezes the data from that exact moment.
What have you done to the truck so far?
Have you done a tune up yet?
Old Dec 3, 2012 | 07:00 AM
Thanks for Gems manual Savannah.
Spike - This is the '5 year mystery' truck you helped with the misfiring being related to the speed sensor or bad ECU.
After replacing the GEMS ECU, the truck ran great for 400 miles. Suddenly, the hesitation problem/misfiring problem came back. And it is also idling poorly occasionally, especially after highway driving and warming up. Oddly enough, the issue is appearing in Bank1 as I watch the short term fuel trim crank up. Historically, the problems were appearing in Bank 2.
Now I am really lost...
Old Dec 3, 2012 | 07:23 AM
Night time total darkness visual check for spark arcs from coil or wire areas? Sometimes misting with a spray bottle of water will bring this out.
Old Jan 29, 2017 | 08:47 AM
GRAVZZY's Avatar
On my truck almost everytime I unplug the ECU then power to the ISV is lost, so I'm aware one or few of the terminals on the engine management harness is a bit loose/dirty. It has been cleaned and greased several times but it's more a band aid than a fix. To make it work again I plug-unplug and wiggle the ECU connectors until it starts whitout holding the gas pedal. I might replace the whole harness is I find one new or from a dry location where it hadn't sprayed with salty water for 20 years... I hope you'll find your misfiring problem as it might explain mine as well.
Old Jan 29, 2017 | 03:16 PM
ihscouts's Avatar
It's been five years since the last post, I'm sure it wasn't resolved. You should start a new thread where you reference this one so folks know the similarities or just keep that in mind the next time.
Anyways.... by you disconnecting and reconnecting the Molex it's actually doing more harm than good because it's wearing out the spring connections in the female side. You might have to grab one off a Pic N Pull or junk yard and reconnect that in order to get away from having so much fun.
cogsley
Aug 13, 2014 03:24 PM
caymandrew
Mar 14, 2013 02:03 PM
schwuller
Feb 9, 2013 09:18 PM
LeakyDisco
Feb 2, 2013 09:13 PM
Robover01
Nov 24, 2009 11:09 AM
