Disco I Overheats with A/c On
I just do not get it. I can pull my 3800 lb boat up a hill on a 100 degree day with the a/c off and temp will never go over about a 1/4 of the way up! Turn the a/c on and all hell breaks loose. Low side on a/c systmes should uns 25-37 psi anytime I have messed with em and this one is running 60psi. DO not know if this is the problem or what. I thought about replacing the expansion valve, drier, pull a vacuum, and recharge and see what happens. Something must be making the condenser get very hot to heat my radiator this badly. I even made sure there wasn't an air bubble at m temp senser and nothing. UUUUHHHHH
not sure what you mean by pusher fans but I am pretty sure when you turn the truck off with the A/C on the e-fans should run for 10 minutes, I would question that. I don't know enough about the cooling/A/C systems in our trucks but that kind of threw a flag for me.
CrimsonRavyn
02-26-2012 09:40 PM
