Disco I Overheats with A/c On
Old Jun 28, 2010 | 10:17 PM
azazel_18_2's Avatar
fins look like new
Old Jun 28, 2010 | 10:22 PM
Long Haul's Avatar
Are your electric fans turning on.... I see you replaced them but are they working with the AC on? Definatly sounds like your not getting proper air flow.
Old Jun 28, 2010 | 10:56 PM
Replaced both. One went down then the other went down. Replaced them both and yes they do work and run about a minute even after I shut the engine down. They are pusher fans.
Old Jun 28, 2010 | 11:04 PM
I just do not get it. I can pull my 3800 lb boat up a hill on a 100 degree day with the a/c off and temp will never go over about a 1/4 of the way up! Turn the a/c on and all hell breaks loose. Low side on a/c systmes should uns 25-37 psi anytime I have messed with em and this one is running 60psi. DO not know if this is the problem or what. I thought about replacing the expansion valve, drier, pull a vacuum, and recharge and see what happens. Something must be making the condenser get very hot to heat my radiator this badly. I even made sure there wasn't an air bubble at m temp senser and nothing. UUUUHHHHH
Old Jun 29, 2010 | 12:52 AM
Rover Chris's Avatar
not sure what you mean by pusher fans but I am pretty sure when you turn the truck off with the A/C on the e-fans should run for 10 minutes, I would question that. I don't know enough about the cooling/A/C systems in our trucks but that kind of threw a flag for me.
Old Jun 29, 2010 | 05:56 PM
I think I would lower the psi in the a/c to spec and see what happens.
If the condenser is dumping to much heat in from of the radiator that would do it.
I dont know how to much psi in the a/c would do that but hell, what do I know?
barryt
Aug 13, 2015 06:09 AM
USNAVYORDNANCE
May 18, 2015 07:27 PM
CrimsonRavyn
Feb 26, 2012 09:40 PM
Knuckle Dragger
Aug 5, 2009 05:40 PM
dips
Oct 8, 2007 05:31 AM
