Disco knock
Finally pulling the heads today. Whats the best way to check for a slipped liner/cracked block without pulling the whole thing out and getting it pressure tested? and what else should I check/look for while it is torn apart?
Not sure I see what you are referring to. I haven't pulled apart the intake on a LR yet, but I've seen cut-outs machined like that on other engines before. Is it the same by all the lifters? Or just those two?(if that is what you are referring to)
This is what I was referring to. I just wanted to make sure. That is the only area that I see such marks and wanted to make sure since I already had it apart.
