Discovery 1 recurring electric fault
Old Feb 25, 2026 | 04:24 AM
nzajg's Avatar
Default Discovery 1 recurring electric fault
My 96 Discovery 1 has spat the dummy with the recurring problem of motor cut-out. Again, on a very hot day, it stopped with no coil voltage. After 25 minutes of cooling, it started. This pattern has repeated over the week, but now has also failed with no voltage to the fuel pump. I replaced the Fuel Pump Relay (K119), which is receiving 12volts on relay terminal 30 (PW) wire from Fuse 6, but there is no voltage on terminals 86 and 85, the latter supplies the ECU (Z132). The odd thing is, there is voltage at Fuse 3, but the connecting WG wire section to connector C216 has no voltage. I recleaned and secured the earth fixture at the rear of the engine. The Spider Security is removed and replaced with a Uniden Security system, but the isolation white wire is not connected, leaving only the hob, door and lights active. I’m at a loss and would appreciate some input. Many thanks in advance. Regards, Tony G, Christchurch
Old Feb 25, 2026 | 07:39 PM
Harvlr's Avatar
What about Crank Position Sensor?
DakotaTravler
Mar 25, 2021 09:04 PM
Austin Busby
Dec 20, 2018 05:12 PM
Dalea
Nov 2, 2016 04:33 AM
vsop4me
Oct 8, 2014 10:32 PM
coldstart
Jan 5, 2014 05:32 PM
