discovery o2 sensors
Old Sep 7, 2010 | 08:03 PM
jkeving's Avatar
Default discovery o2 sensors
Just got a '98 disco for my daughter. 1 owner, 84k miles. Starts, runs great. However, the previous owner simply cut off the wires from the front O2 sensors. Rear ones are intact.
Am replacing them but, cannot find the wires/plugs for the sensors anywhere.
Where can they be hidden???
Throws 1 code (P1185) for O2 sensor heater.
Thanks for your help
Old Sep 7, 2010 | 08:26 PM
tweakrover's Avatar
they are attached to the back of each head held on by little metal clips.
Old Sep 8, 2010 | 08:43 AM
okdiscoguy's Avatar
RAVE manual in my sig has all you will need. It is like a Haynes manual, only has everything...
Old Sep 8, 2010 | 06:41 PM
You can swap the fronts and rears as they are the same on a DI and leave the rears non functioning as the rear O2's do nothing except tell the ecu that the cats are working or not.
Old Sep 8, 2010 | 06:48 PM
Danny Lee 97 Disco's Avatar
Spike, was totally unaware of that piece of info.
JK, you got one lucky daughter, hope she appreciates it. That is really low miles on her new Disco.
Old Sep 9, 2010 | 06:49 AM
Rover Chris's Avatar
don't know if you found them yet but middle of the firewall, behind the engine, straigth down sitting on top of the tranny bell housing there is a harness and the front connectors are respectively on each side of that harness (and they both run up into that harness)
Old Sep 9, 2010 | 06:57 AM
Jull's Avatar
And those plugs are a PIA to get to unless you have really tiny hands
Old Sep 12, 2010 | 06:59 PM
jkeving's Avatar
Thanks all for the help. Yes, it is shockingly clean, will post pictures, and will make sure she takes care of it!
duke051184
Jan 18, 2013 01:52 PM
mylesman12
Aug 31, 2012 06:06 AM
Guapo2004
Mar 14, 2011 09:46 PM
benflynn
Oct 10, 2008 08:19 PM
discovery101
May 21, 2008 07:58 AM
