Do you have death wobble? Please read!
Old Jan 1, 2012 | 09:28 PM
s12512's Avatar
What size bolt is that??
Old Jan 3, 2012 | 08:51 AM
thehun's Avatar
Originally Posted by DiscoBritney
First time I took Clover on the highway and hit a bump it went crazy on me. Told a mechanic and he told me everything except the moon could be causing this problem and repair would be rather expensive.
Found this thread tightened the bolts, #11 was exceptionally loose, and it cured it 100%, take that Mr. Lying Mechanic
Brit and Clover the Rover
That is the reason why it pays off to know your vehicle...mechanics will rape you just because it is a land rover
Old Aug 4, 2012 | 11:32 PM
mrwizard's Avatar
4th Gear
Mine's doing this too. It's time to check it out. Thanks for the info.
Old Aug 6, 2012 | 01:24 AM
dragonhead's Avatar
Do as antichrist suggests and check out his thread on death rattle. It would do us all good to know what to do to diagnose the actual cause. The bolt is just one possible cause. As stated, it could be the suspension. I'm suffering the same. My bet is on my shocks that no longer have their upper bushings. They make a hell of a racket whenever I move the truck, which these days is usually just around the apartment complex parking lot. Sigh...
Good luck all.
Old Aug 6, 2012 | 09:26 PM
mrwizard's Avatar
4th Gear
Good luck all.
Did I miss the link to that thread? I checked the threads he started and didn't see it. Thanks.
Old Aug 6, 2012 | 09:28 PM
mrwizard's Avatar
4th Gear
Found it. Post #4.
https://landroverforums.com/forum/di...19/#post288875
Old Aug 6, 2012 | 10:34 PM
jfall's Avatar
Also
Replace the panhead bushing - there are two on the left and right.
These will cause the death wobble also.
I am living the death wobble now.
To get the wobble to stop violently shake the steering wheel back and forth to counteract the oscillation.
Old Aug 7, 2012 | 04:36 AM
antichrist's Avatar
Originally Posted by DustyLBottoms
Most steering shaft bolts I've seen over the years at the dealer level have lock-tite.
You're right. I got a new steering shaft a while back and the bolts came with it applied.
Old Sep 16, 2012 | 10:05 PM
JPSpen's Avatar
Mine was a loose steering box. I could turn the bolts by hand.
John
Old Sep 17, 2012 | 07:18 AM
DiscoJag's Avatar
I had it pretty bad. I jacked up a side in front and pulled and yanked on the wheel and I could feel the play in the swivel pins. I went ahead and pulled the hubs and re-packed the wheel bearing and adjusted the swivel preload by removing a couple of shims. I followed a post on here on the swivel pins. Nothing too complicated, just old-fashioned heavy duty wrenching and very greasy - lots of fun. I don't think either job had been done before, so it's about time.
antichrist
Feb 25, 2020 08:50 PM
Rover Chris
May 23, 2015 02:13 AM
blaze98
Sep 21, 2010 07:14 PM
mrcrptguy
Apr 9, 2009 06:02 AM
pelias
Sep 8, 2008 09:47 PM
