The dreaded leaking sunroof???
Old Jan 16, 2012 | 01:07 PM
  #21
Mr. Clean's Avatar
Originally Posted by psykokid
makes sense, the drain channels are at the front of the sunroof assembly, with the truck angled uphill the water is going to overflow the drip rail and leak if the sunroof seal isnt good..
Are the seals easy to replace? Can you clean the drains without taking the head liner out/ down?
Originally Posted by kenk
Yes, D1 and D2 sunroofs are exactly the same, totally interchangable( i believe).
This is good to know...
Old Jan 16, 2012 | 07:57 PM
  #22
Danny Lee 97 Disco's Avatar
Afraid not. But if you have issues with the sunroofs, it is best to go ahead and remove the headliner (not the sunroof) and deal with the sunroofs. The longer they leak, the more damage will be done to the headliner.
The drains are large clear plastic tubes routed behind the headliner to the side rails. The sunroof frames also can leak at the corners and need to be sealed with caulking.
Last edited by Danny Lee 97 Disco; Jan 17, 2012 at 06:16 PM. Reason: correct typos
Old Jan 17, 2012 | 10:13 AM
  #23
Mr. Clean's Avatar
Afraid not. But if you have issues with thye sunroofs, it is best to go ahead and remove the sunroof and deal with the sunroofs. The longer they leak, the more damage will be done to the headliner.
That is what I was afraid of... Thanks for the info. New Sunday project.
s10lowrider1994
Sep 27, 2023 09:40 AM
Sbonomo
Jan 24, 2009 11:09 AM
Sbonomo
Jan 21, 2009 03:20 PM
OlDood
Jul 4, 2007 10:23 AM
skrams
Dec 29, 2006 09:57 AM
