Driver Door Lock not working with FOB
Old Mar 9, 2021 | 08:43 PM
robbyb20's Avatar
4th Gear
Default Driver Door Lock not working with FOB
Last night I had to replace the spring in the lock mechanism for my driver door since it wasnt opening. The spring replacement went fine and the door opens from inside'/outside without needing to hold the key in.
My current issue is that once put back together, the driver door lock isnt locking/unlocking if I use the FOB.
When I have the driver door open, and i "lock" the car via the internal door lock, you can hear the rest of the locks lock and then unlock since the door is open like its supposed to. if i get in and lock the door via the internal lock, the rest of the car locks. If i lock from outside the car with the key, the whole car locks. if i use the FOB, every door execpt the driver door locks/unlocks.
It appears the master locking system is functioning correctly except the fact that my driver door isnt unlocking automatically.
I have an extra passenger lock actuator and have swapped motors of the 2 devices and it worked for 2 tries and then died. is this just a burnt out motor issue?
Old Mar 10, 2021 | 08:09 AM
WaltNYC's Avatar
Try looking the doors from the inside (doors closed) with the front passenger lock. What is the behavior of the driver's door lock?
Old Mar 10, 2021 | 09:26 AM
robbyb20's Avatar
4th Gear
While in the car with all doors closed. Locking/unlocking the front passenger lock does not have any effect currently.
Doing the same with the drivers door locks/unlocks all the doors.
acg
Feb 27, 2021 05:41 AM
SmithZ80
Jul 9, 2020 08:27 PM
houm_wa
Sep 10, 2019 03:33 PM
mooni
Jan 5, 2015 09:38 AM
AZRover
Feb 10, 2013 12:00 PM
