Vexing door lock issue...
Old Sep 6, 2019 | 08:48 PM
houm_wa's Avatar
Default Vexing door lock issue...
Okay, I feel like I've encountered this before either myself or on this board, but can't recall.
I lock the door with the FOB. The lights flash per usual. The rear doors and psx front locks. The driver side front appears to lock, but from the outside it can be opened....and then the alarm goes off.
Anyone experience this?
Old Sep 6, 2019 | 09:18 PM
Mine does that as well but its the passenger front door
Old Sep 6, 2019 | 09:55 PM
DakotaTravler's Avatar
Same here. So I have the habit now of pressing the lock on the FOB three times, that is always enough to get a proper lock.
This is likely your problem, but this video was not well made in the sense that you need to watch til the end. He tries on fix and it does not work, in the end he try another method and it works.
Old Sep 7, 2019 | 12:37 PM
abran's Avatar
its your actuator for sure. I have fixed one before, but as a general rule I just replace with new for another 10 years of service.
Old Sep 7, 2019 | 01:55 PM
I assumed it was the actuator but hit the button twice and its fine
Old Sep 8, 2019 | 12:53 PM
abran's Avatar
I can’t explain it, but I’ve seen it. Actuator fixed it.
Old Sep 9, 2019 | 02:16 PM
houm_wa's Avatar
Part Number?
Old Sep 10, 2019 | 08:19 AM
Identamerican's Avatar
The actuator is super easy to remove and fix, it only took me about a half hour. Permanent fix and it only costs you time.
Old Sep 10, 2019 | 11:58 AM
houm_wa's Avatar
Hmmmm.....and the "fix" is per the video above? We never really saw the before state of the metal he bent.
Old Sep 10, 2019 | 03:33 PM
I suppose once you actually pull out the actuator you will understand why it works, the metal piece isn't the problem it's the plastic that gets worn over time from what I remember. Bending the metal piece accounts for the wear on the plastic.
It definitely solved all my locking problems.
mooni
Jan 5, 2015 09:38 AM
mzcharj
Oct 27, 2014 02:23 PM
Camdisco24
Feb 2, 2014 02:28 PM
muddybuddy
May 29, 2009 03:44 AM
rravenn13
Jun 29, 2007 02:46 PM
