Drop Arm Nut..
Old Oct 24, 2012 | 07:53 PM
JPSpen's Avatar
Default Drop Arm Nut..
Can someone tell me the size of the nut holding the drop arm to the steering box...
I got a 36mm socket thinking that was right but it's either 34 or 35...
I measured about 1 3/8 with my tape measure ....
I looked in the rave but couldn't find it..
So I posted... And ten minutes later I found it.. I spent an hour + before posting.. Anyway, It's 34mm...
Mods can nuke this thread if they like...
JOhn
Old Oct 24, 2012 | 09:25 PM
fishEH's Avatar
Actually mine's a 33mm. I know because I bought s socket especially for it. Couldn't get it tight enough with an adjustable wrench. Now I use the socket, breaker bar with a short cheater bar on the end of that.
Old Oct 25, 2012 | 11:44 AM
wheelgarage's Avatar
I hope that one comes right off....
I had to cut the arm off mine. It was frozen on there pretty good. Just in case, soak it with some penetrating fluid beforehand.
Old Oct 25, 2012 | 01:53 PM
JPSpen's Avatar
Got the nut off no problem... That 3' long 1/2" breaker bar comes in handy. One big pop and it was loose....
Not so much with the arm...
I can't imagine it being rusted on there with as much fluid as it's been bathed in...
Penetrating oil on now..
John
Old Oct 25, 2012 | 03:42 PM
fishEH's Avatar
I had to use a three armed puller. Heated it, sprayed it with penetrating oil, and whacked it with a hammer repeatedly while under tension from the puller. Finally it popped.
Old Oct 25, 2012 | 03:56 PM
Racer X's Avatar
This.
An impact gun (electric or pneumatic) will have the same effect with a puller, FYI.
Old Oct 26, 2012 | 06:43 AM
fishEH's Avatar
Originally Posted by Racer X
This.
I was talking about the arm, not the nut. The nut came off easily. I had to beat the drop arm off.
Old Oct 26, 2012 | 08:33 AM
Racer X's Avatar
I meant the arm.
If you use an impact gun on the puller, rather than a wrench, you'll have the added benefit of hammer strikes (the gun does have an internal hammer, that's how the whole impact business works) while you're tightening the ram bolt on the puller.
Once the ram bolt reaches maximum torque, all the rest is hammer blows. With my 1/2" electric DeWalt, it's never taken more than 10 seconds on the trigger to reach separation of the arm, and that's working on Northeast cars and trucks.
Old Oct 26, 2012 | 09:11 AM
Rovin4life's Avatar
not all the time, lots of time under tension the hammer is the safe way to go before damaging the puller and it breaking on you.
Old Oct 27, 2012 | 09:46 AM
JPSpen's Avatar
Broke my puller using both impact driver and a 3' breaker bar on the puller stud...
It really didn't matter anyway.. Advance Auto Parts couldn't deliver my new box..
Turns out there's a really good Rover guy about 30 miles from the house..
You should have seen the Jags, Rovers, Bentleys and other British cars there..Taking my camera when I go back to pick it up..
He's got the box now and is rebuilding it for me.. Should be ready Monday or Tuesday... I took it to him drop arm and all...
$250.00 for the rebuild... I think that's a fair price...
John
antichrist
May 12, 2011 12:33 PM
Disco Mike
May 4, 2011 07:08 PM
Brad S1
Nov 17, 2006 11:31 AM
pom1987
Apr 20, 2006 04:37 AM
freeranger
Mar 29, 2005 06:03 PM
