Edumucate me on O2 sensors
Old May 8, 2013 | 01:27 AM
Rover_Hokie's Avatar
Savannah, do you have this same document for the Bosch 4.0?
Old May 8, 2013 | 06:29 AM
RacerX's Avatar
Originally Posted by zigzag3141
Fix the cooling system problem and get your Tstat put back in. You should get to normal operating temp (180-200) within 5 minutes of driving regardless of ambient temps.
On another note, is the whole open/close loop thing on the UG is backwards and has a lot of people confused. By definition, an open loop controller makes adjustments a setpoint variable (like your air/fuel mix) without feedback (as would be the case when you ECU runs its warm up problem and injects a constant amount of fuel). A closed loop system interprets feedback and automatically adjusts the set point (as the case when the ECU reads your temp/O2 data and makes adjustments to the air/fuel mixture).
You want your truck to run in closed loop at normal operating temps but you will never get there if your ECU thinks you're still in warm up mode.
Yes, of course this makes perfect sense...I never was much of a controls guy but I guess had I thought about it for more than 2 secs perhaps I'd have realized this. I'll blame it on the UG throwing me off. ; )
I hope to get to the cooling system this weekend but this is not my daily driver so I'm not suffering. Still sucks to take a short run to the shop and burn 4 gals of gas though. I will be most certain to post follow up on all this too.
Thanks again for all the replies, very helpful!
Old May 8, 2013 | 06:35 AM
RacerX's Avatar
Originally Posted by CUpgt
I get 12-13 mpg. Going to replace the upstream o2s and plugs and hope for the best. Truck is well cared for, runs right at 185, etc... 33s will do a number on gas mileage though. I'm just glad my DD gets 27-28 mpg
Are you taking into account the diam difference in that? Just curious, it's quite a bit of course. I think I'm going to go ahead and replace plugs/wires and possibly coil packs. I've not looked into the coil packs...looks like 1/cyl pair so QTY 4 needed. Anyone know what the OEM brand is...Lucas, Bosch, other, ??
Cheers.
Old May 8, 2013 | 06:54 AM
Rover_Hokie,
Follow link in my signature to a cloud stored version of the Bosch ECU manual. Or this link https://www.cubby.com/pl/LR3+worksho...uter%20Manuals
Old May 8, 2013 | 07:06 AM
RacerX's Avatar
Put in a stat, about $10 plus gasket.
On the GEMS engine, here is what the ECU book has to say -
P0125 - Engine Coolant Temperature - Warm up time limit, [closed loop fuel] typically 90 seconds at 20oC start temperature
and
This checks that the engine has gone into closed loop fuelling within a given time, (the engine coolant information is the only sensor it depends upon).
GEMS ECU manual attached, more that most want to know about O2s, codes, etc.
Thanks dude, I dl'd the manual, I'll have to flip through this the next time I'm visiting the oval office.
Cheers.
Old May 8, 2013 | 07:38 AM
one guy downloaded the RAVE and printed the shop manual... I always thought you should get an 80 inch flat screen so it can be viewed easily in the shop during commercials...
ITMagician
Sep 20, 2015 08:47 PM
jsyonker
Sep 4, 2011 06:01 PM
Corsair33
Sep 18, 2006 10:15 PM
riebs
Aug 21, 2006 11:48 AM
JRdisco1
Aug 9, 2005 03:33 PM
