Electric front windows stopped working
Old Sep 14, 2018 | 03:42 PM
Mark. Rossow's Avatar
4wd High
Default Electric front windows stopped working
Fuse below dash is good. Have ~10.5 V at both front switches ( more like 11 V at both rear switches, although the readings are doubtless lowered by my random grounding of the electric meter against the carpetless floor... .
_both_ front windows went out at same time
Old Sep 14, 2018 | 08:23 PM
stillruns's Avatar
Do they move at all? And up/down action or nada.
Old Sep 15, 2018 | 02:50 PM
4wd High
Total zer0 for both front windows.
Luckily they were up already !
Both rears are working normally.
Old Sep 15, 2018 | 03:35 PM
Danteross77's Avatar
8th Gear
I've had just about every door panel off mine in the last 2 years for either window regulator, window motor, or door lock actuator. Fairly common I believe. When I first bought mine the driver side window wouldn't work, bought the cheap one of ebay from Brit Parts($40). Worked for about 6 months then stopped working. Drove around like that for a few months them my passenger side regulator broke, window all the way down and wouldn't stay up. Went to the junk yards and pulled 2 used motors and back in business every since. Fairly easy to do, there are a few videos on youtube. I practiced on the ones in the junkyard just so I wouldn't tear mine up. I would say first time will take a few hours after that its a 30-45 minute repair. I think I paid about $20 each in the junkyard.
Old Sep 15, 2018 | 04:14 PM
4wd High
Both front windows went totally dead at the same time
Old Sep 15, 2018 | 04:53 PM
8th Gear
I would at least pull the panel and see if you have current where the motor plugs in, you can do that without pulling the window regulator. Stranger things have happened with British electronics. Just my thoughts.
Old Sep 15, 2018 | 05:35 PM
stillruns's Avatar
Pull the door card and inspect/check the motor, etc. Check fuses also.
Old Sep 16, 2018 | 12:56 PM
4wd High
re-soldering at ECU is an an idea from someone else.
Anyone done that ? Tips ?
Old Sep 17, 2018 | 08:02 AM
WaltNYC's Avatar
Yes, there is a youtube video. A guy with one arm can do it (literally, watch the vid). Sort of a pain in the *** to get the board in/out, but not difficult.
The same solder point which was bad in the video failed on mine.
I recommend a little dielectric grease on the connector when reinstalling.
Old Sep 21, 2018 | 08:36 AM
jimvw57's Avatar
I have done the soldering the ECU 3 times now. last time was for the front pass window. before that it was for the rear windows. When you pull the board and take a look, you can see the failed solder joint. I finally got a used board so I ca just swap it out and fix the broken one later and put it on the shelf
Matt Thaller
Sep 21, 2015 08:36 AM
TattooedLRD
Aug 29, 2013 11:48 AM
LeakyDisco
Jun 21, 2013 08:22 PM
disco1idaho
Jul 15, 2012 06:21 PM
vips_one
Oct 6, 2009 11:01 PM
