Engine has rough idle after running?
After 8 months of painless rover bliss I 'm back to pay homage to my fellow Rover nuts! I have two problems not sure if they are related.
ONE-When starting the engine cold, it sounds like an exhaust leak on the drivers side engine bay then goes away after it warms up.
TWO- After driving around town. Car idles fine at shutdown, but let it sit for 5min than try to start it while it is hot and the engine runs rough at idle than eventually smooths out after a few mins of rough idle.
Here's what I have done.-Cleaned intake, replaced plugs and wires. Coolant level is fine no leaks, Oil lost a little less than a quart over 8months. Any suggestions?
Is there any way to test the fuel temp sensor? It is a bit pricey to just slap a new one in.
Or are they somewhat standard, and can use a non-OEM one?
(Am having exact same issue -- re-starting when engine is warm can cause low rpm or stall, but then is fine with a bit of gas and once it gets going again.)
Fuel temp sensor spec is:
• NTC type sensor [mean resistance goes down as it heats up]
• Range = 23k-ohm at -30 °C (-22°F) to 290ohm at 80°C (176°F).
Approx. 1.1 k-ohm at 40°C (104°F)
• Located on the fuel rail by cylinders 3 and 5
dillhole
Feb 20, 2020 02:30 PM
