Engine Issues? :)
Old 09-01-2013, 09:24 AM
nuclearw's Avatar
Originally Posted by fishEH
I gotta stop by one day while you're working!
Does the black plastic have a horizontal seam? They were known for separating there.
Lol that'd be cool ... wish I could actually plan when i can work on it haha .. Put the new rockers on last night after kids went to sleep... lol
As for the tank yes it has a horizontal seam...... I'll send a message over and see whats up.
  #42
Old 09-01-2013, 10:26 AM
fishEH's Avatar
What are your thoughts on wheeling the 21st? I'm going and got a seat open if you're interested.
  #43
Old 09-02-2013, 09:29 AM
nuclearw's Avatar
Dang would love to ... bit of a clue into the crazyness round here got 2 weddings this month and serving as sound "engineer" at church ... so 3/4 weekends kinda shot
Baby's due in Oct so reluctant to mozy too far from the ranch ... got anything planned for dec/jan?
  #44
Old 10-10-2013, 12:35 PM
Mattvail's Avatar
Any chance running some seafoam through the crankcase would resolve these issues? I'm not looking forward to doing this job to my Disco 1. My drivers side valve cover gasket is leaking. Had my passenger side replaced several years ago and it's holding up. I'm going to do the job on tv drivers side I just don't want to mess with the innards.
Soaked it in degreaser overnight and WHAT A DIFFERENCE... the oil port on #8 was blocked a bit i figure dthats why it had the darker color, cleaned up and looked fine. pushrod looked perfect as well
The drivers side I cannot say the same for....
Found 1 that is definitely broken, and one that is suspect....
Here are some images, scaled down for you ihscouts
The one that is suspect doesn't appear to be missing the button, but the top of the pushrod has a slight lip around the outside
Next question is this:
can I replace the 2 damaged rockers and their respective pushrods, or do I need to replace the entire rocker assembly................. and looking at rovahfarm there are several rockers available, how the heck do I know which one I need
  #45
Old 10-10-2013, 12:39 PM
nuclearw's Avatar
ehh if your referring to the rockers & the clicking no....
As for the rest, the carbon itself is not an issue per se, I cleaned em cause I had them out anyway...
As for the rocker covers, just see if you can tighten the bolts careful tho they snap easy.
I had to get a 12pt 8mm deep socket from Lowes.. nowhere else local had one in stock, the 3/8 drive has a taper down that helps it to fit decen.
The whole process of getting to the rocker cover is pretty painless, you only have to remove the upper plenum and a few associated items.
  #46
Old 10-10-2013, 02:26 PM
Mattvail's Avatar
Thanks for the response. Was doing some addition research and I was wondering if my problem is originating at the oil seperator? When I was swapping out my plugs And doing a throttle body job this past weekend I noticed a pretty solid amount of oil coming from the oil seperator. So I pulled off my PVC and found that there was quite a bit of build up going into the throttle body. Cleaned it out with carb cleaner and several qtips. Anyways, I will retighten. Thanks for your help
QUOTE=nuclearw;425189]ehh if your referring to the rockers & the clicking no....
The whole process of getting to the rocker cover is pretty painless, you only have to remove the upper plenum and a few associated items.[/QUOTE]
  #47
Old 10-10-2013, 05:40 PM
fishEH's Avatar
1/4" drive, 12pt deepwell 5/16" socket for the valve covers.
zukman89
04-25-2008 10:21 AM
pboerger
03-20-2008 08:22 AM
tcbinaflash
01-08-2008 04:23 PM
msturdy
07-13-2007 11:04 AM
TrickyWhu
01-02-2007 11:16 AM
Quick Reply: Engine Issues? :)
