engine options
Old Mar 25, 2012 | 12:59 AM
erikstevens's Avatar
Default engine options
Hi everyone, I hope this question dosen't offend anyone.
I have a 2000, ford diesel V8 7.3L. I would love to drop it in a 1997 Discovery. Is this posible or even logical?
Any help would be appreciated.
erik
Old Mar 25, 2012 | 08:26 AM
Higgs Boson's Avatar
Anything is possible, even when not practical. That 7.3 weighs several times what the rover engine weighs, so you would need much heavier front springs. The weight will likely be a burden to the existing braking system also. The torque will most likely destroy the diffs and entire driveline in short order. You still need to sort out what transmission you would use and a means of adapting it to the LT230, or change the complete setup to something that you could just bolt in. You may run out of length though, the ZF and LT230 are fairly compact. You will have to keep in mind the LT230 output is offset, that may get interesting when trying to fit a rear shaft. This all would cost you several times what the truck is worth, perhaps more.
I was looking at the possibility of swapping a 4.6 Ford DOHC into a Disco. Looking at them side by side I decided I would fix the Rover engine. It's a simple setup that works for it's intended purpose.
You can do whatever you want if you have enough money.
Old Mar 25, 2012 | 09:39 AM
ngarover's Avatar
Yesterday I was looking at my 7.3 and came to the same conclusion, The 7.3 is 1000 pounds by itself! Leaning toward a 2.8 isuzu diesel instead...
Bryan H
Dec 18, 2022 10:51 PM
Spray
Mar 19, 2011 08:43 PM
Bryan H
Jun 9, 2010 10:05 AM
lifewithoutanet
May 19, 2009 07:17 PM
doerhoff013
May 19, 2009 05:51 PM
