Engine or transmission vibration
Old Apr 8, 2023 | 02:16 PM
Harvlr's Avatar
Also, can I get a look at the flex plate without removing the transmission?
Old Apr 9, 2023 | 10:40 AM
JohnZo's Avatar
Probably could get a small inspection camera in there. My mechanic uses a small diameter one that links to a phone. Focus can be tricky. At least look through every hole and cover plate.
Old Apr 9, 2023 | 01:29 PM
Best4x4's Avatar
You can remove the lower inspection plate and look at it, but it usually gets cracked around the 6 bolts in the center and the cracks work their way outward. You should be able to spot the outer cracks as little black lines.
Old Apr 9, 2023 | 02:03 PM
Harvlr's Avatar
Thanks. I’ll check it out
Old Apr 10, 2023 | 12:53 PM
WaltNYC's Avatar
Here is a video from when I suspected a flex plate issue on my 1997 D1. You can't see much of the flex plate. I used a boroscope to examine the condition of the flex plate.
Old Apr 10, 2023 | 07:05 PM
Harvlr's Avatar
Thanks for the video Walt. On my next days off I want to look at a few things. Something simple and easy would be nice but I’m anticipating worse.
Ianperrott
Freelander
Jan 26, 2023 08:43 AM
cobbcj7
Jun 13, 2013 11:58 AM
Overfinch580s
Feb 5, 2013 06:51 AM
lagebrooks
Jul 20, 2006 11:53 AM
LiftedRover96
Feb 7, 2006 10:41 PM
