fast blinker
Old 07-02-2015, 02:53 PM
TOM R's Avatar
mine was blinking so fast the trailer did not blink unless i applied brakes but i am away working for another week so i will need to check the plug with a tester i guess, was just wondering why the trailer on dash does not light up now
Old 07-05-2015, 06:45 PM
TOM R's Avatar
So more weirdness, needed to use a trailer today, no turn sig at plug, used a plug in testor and left it sit key on, t/s on and after 5 minutes it starts blinking??? Did the other t/s and same thing now they work ????
It was like the truck had to relearn which makesnjo sense on this old?
Old 07-05-2015, 06:55 PM
philwarner's Avatar
If you'll excuse the J word, my Grand Cherokee and ons side flashing fast and it was caused by corrosion and bad contact in one of the rear signal/brake lamps. Cleaned the lamp contacts and it was back to normal flashing.
Old 07-13-2015, 04:47 PM
TOM R's Avatar
OK this is just stupid, when I use a turn signal with or without trailer on the little trailer light on dash no longer comes on, I have no turn signals at trailer plug unless I hit the brake pedal ????
Is my trailer adapter shot or something wrong in the rover????
Old 07-13-2015, 08:12 PM
TOM R's Avatar
Well guess the draw tite harness adapter died? Put in the factory one I got from u pull , everything on trailer works now, still no little green trailer light above turn signal indicator on gauges
Old 07-13-2015, 11:06 PM
XCELLER8's Avatar
Tom, I had a similae situation on my 95....I have come to the conclusion that the "MFU" is the culprit on the no trailer indicator, I have everything hooked up factory like, all lights working, no trailer indicator.....had mfu troubles with it before, no intermittent wipers, no rear wiper.....just livin' without the indicator
Old 12-12-2023, 08:31 AM
manatee2000@gmail.com's Avatar
No offense, but to use any other as an analogy for problems with a Land Rover is a mistake. Grand Cherokee and Land Rovers are totally different electrical systems and can't be compared to one another.
dusty1
06-08-2015 09:11 AM
snowdude
12-17-2008 07:58 PM
2low2rl
11-11-2008 07:23 PM
nuno
05-23-2007 08:39 AM
maxferran
12-15-2006 11:48 AM
Quick Reply: fast blinker
