fast blinker
Old Jul 2, 2015 | 02:53 PM
TOM R's Avatar
mine was blinking so fast the trailer did not blink unless i applied brakes but i am away working for another week so i will need to check the plug with a tester i guess, was just wondering why the trailer on dash does not light up now
Old Jul 5, 2015 | 06:45 PM
TOM R's Avatar
So more weirdness, needed to use a trailer today, no turn sig at plug, used a plug in testor and left it sit key on, t/s on and after 5 minutes it starts blinking??? Did the other t/s and same thing now they work ????
It was like the truck had to relearn which makesnjo sense on this old?
Old Jul 5, 2015 | 06:55 PM
philwarner's Avatar
If you'll excuse the J word, my Grand Cherokee and ons side flashing fast and it was caused by corrosion and bad contact in one of the rear signal/brake lamps. Cleaned the lamp contacts and it was back to normal flashing.
Old Jul 13, 2015 | 04:47 PM
TOM R's Avatar
OK this is just stupid, when I use a turn signal with or without trailer on the little trailer light on dash no longer comes on, I have no turn signals at trailer plug unless I hit the brake pedal ????
Is my trailer adapter shot or something wrong in the rover????
Old Jul 13, 2015 | 08:12 PM
TOM R's Avatar
Well guess the draw tite harness adapter died? Put in the factory one I got from u pull , everything on trailer works now, still no little green trailer light above turn signal indicator on gauges
Old Jul 13, 2015 | 11:06 PM
XCELLER8's Avatar
Tom, I had a similae situation on my 95....I have come to the conclusion that the "MFU" is the culprit on the no trailer indicator, I have everything hooked up factory like, all lights working, no trailer indicator.....had mfu troubles with it before, no intermittent wipers, no rear wiper.....just livin' without the indicator
Old Dec 12, 2023 | 08:31 AM
manatee2000@gmail.com's Avatar
No offense, but to use any other as an analogy for problems with a Land Rover is a mistake. Grand Cherokee and Land Rovers are totally different electrical systems and can't be compared to one another.
dusty1
Jun 8, 2015 09:11 AM
snowdude
Dec 17, 2008 07:58 PM
2low2rl
Nov 11, 2008 07:23 PM
nuno
May 23, 2007 08:39 AM
maxferran
Dec 15, 2006 11:48 AM
