a few question 98 disco
Old Dec 5, 2011 | 12:53 PM
alpinacsi's Avatar
To fix the sunroof leak properly; you will need to remove the headliner(might be able to drop the rear down). Most likely the drains are the source of the leak and will need to be resealed. The drain tubes attach to a small plastic tray that is attached to the metal retaining tray for the sunroof. The plastic parts are sealed to the metal with caulking and most likely need to be resealed. If you headliner needs to be reworked because the material is dropping: this is the perfect time to fix both sunroofs and any windows that leak.
Old Dec 5, 2011 | 01:55 PM
Danny Lee 97 Disco's Avatar
Another issue to be aware of with the dash lights and tail lights going off when you switch the headlights on is the turn signal stalk switch. The switch is built in and when you go from just the parking lights to headlights it can kill the dash and taillights if the switch goes bad.
The fix for that is either replace the stalk switch or take it apart and clean up the contacts and reassemble. I chose to replace mine with a used one from Will Tillery at a great price. Paul Grant may also have one.
Old Dec 5, 2011 | 04:24 PM
olywa's Avatar
okay going to pull the to make sure i get the right one. I have to removed the rear jump seats!! this is getting more fun as we speak. is there resale value in the rear jumo seats?
i hope it is just the bulb and the blinker switch.
Old Dec 5, 2011 | 06:06 PM
LeakyDisco's Avatar
Yes, there is a resale value for the jump seats since (I believe) they are harder to find new, if at all. I recently purchased a set of jump seats for my SD from eBay. Check prices there. Between $200-300 seems to be average for the complete set (seats, and all mounting hardware, belts) in good to excellent condition.
Old Dec 5, 2011 | 06:50 PM
LeakyDisco's Avatar
If neither, check your glove box lamp. If it doesn't work when the headlights are switched on, check the fuse and confirm the lamp isn't shorting on the metal bracket that holds the assembly in place. That's what it was for me.
Old Dec 5, 2011 | 06:56 PM
Drop that headliner to get to the problem on the sunroofs. It would be a shame to waste good sunroofs sealing them shut!
Old Dec 5, 2011 | 07:45 PM
The sunroofs will not leak if they are closed and the seals are good.
But if the seals are bad then you need to club them and then seal them shut.
Old Dec 5, 2011 | 07:46 PM
olywa's Avatar
bulb pulled and it looks good, i replaced it and still not luck. going to check out the glove box lamp.
Old Dec 5, 2011 | 07:53 PM
The headlight switch is not to expensive and is not to bad to replace.
The DI and DII both use the same switch so you can buy a used one off e-bay or whatever.
Old Dec 5, 2011 | 08:16 PM
olywa's Avatar
glove box lamp doesnt work with the headlights on or off.
