finally had a chance to put the OME stuff on....
Old Feb 12, 2012 | 11:50 PM
ValveCoverGasket's Avatar
Default finally had a chance to put the OME stuff on....
figured everyone likes to look at pictures...
and i thought id throw in a few shots of the before/after height.
didnt get any pictures of the truck outside on the ground afterwards, but you can use your imagination
i think the rear springs were likely a bit saggy. but to be sure the old suspension was definitely soft. i like the ride now, a bit stiffer but nice.
shocks were the 60037 and 60039 and the springs are 2751 and 2762. tires are 235/70/16 as well, in case anyone wants to compare heights... OME advertised 2" lift, and it appears to be exactly as advertised
i also opted for the lowered rear mounts "while i was in there". the droop seems to be significantly better with the new setup as well (though i didnt measure, but we did have to raise it on the lift a few inches to get the tires back on after installing the new stuff). the longer brake lines probably werent as necessary on the fronts, but were pretty much mandatory IMO on the rears after seeing it at full droop they were basically acting as limiting straps hah
i guess the hunt begins for a decent set of used 235/85s! hah
anyway, onto the pictures. enjoy
Old Feb 13, 2012 | 06:12 AM
slanginsanjuan's Avatar
VCG....looks real nice. I'm surprised the difference isn't night and day. Colors all work too. Any cut bumpers, ghetto grills or protection coming? Is that your garage? Let's see a pic of the whole truck farther back tho?
Old Feb 13, 2012 | 09:21 AM
EricTyrrell's Avatar
Looks great, but it looks like the front went from 33-1/2 to 34-7/8. That's a 1-3/8 lift. Rear 32-7/8 to 34-3/4. That's a 1-7/8 lift.
Old Feb 13, 2012 | 10:05 AM
youre right of course, i figured i was close enough haha
yes, thats my shop. ill try to get a snap of the whole truck now from further back... there is a difference but its certainly not huge.
no cut bumpers or ghetto grills yet... im waiting to finish up some other projects and i might spring for an ARB bumper, but its really pretty low on the list. before any of that though ill be replacing these tires, as theyve got some cuts in the sidewalls and will probably need changing after this ski season.
next up is a set of gauges - oil temp/oil pres/coolant - and a tstat change, probably in a week or so if i can find time.
xb70valkarye
Mar 15, 2009 06:46 PM
Camdisco24
Sep 26, 2008 07:17 AM
George Dow
May 1, 2008 11:44 AM
starcraft
Dec 17, 2007 09:12 AM
