Fixed my rear windows finally 97 D1
Old Mar 15, 2020 | 07:14 PM
denverdisco1's Avatar
Default Fixed my rear windows finally 97 D1
Finally got around to pulling off the door panels and fixing the windows that have been duct taped for too long.
Used a nylon washer I found at ACE Hardware.
The windows stopped going up and down so had to tackle the control board.
Didn't see the normal place that people solder but I did see some discolor on the strange wires that rise from the board.
After heating them up and adding a bit of new solder, preso the fkn thing worked.
I was getting ready to do the bypass with the white & green wire but didn't need to.
Any questions, hit me up, since mine is a US Rover and a lot of the instructions are for a right hand drive D1.
Steve
Old Mar 15, 2020 | 09:26 PM
jimvw57's Avatar
I replaced the control board on my '99 D1, and the back seat window on pass side works, drivers side now makes noise but doesn't move. I took the door panel off and looks like the motor is turning, but no movement of the regulator. guess I'll leave it for later as I have plenty to fix for now.
I usually use a magnifying glass and a strong light to inspect solder joints and like you did, hit any that look suspect.
devildollnyc
Jun 1, 2020 01:59 AM
Motorvated
Aug 16, 2013 10:30 PM
bcbp
Feb 3, 2013 04:40 PM
Captian Adrianus
Jul 14, 2012 07:26 PM
lgerhardt
Jul 8, 2008 10:01 PM
