Found my coolant leak! Fix or replace oil cooling joint?
#21
That Rad looks promising for sure. The shop should without issue be able to braze the nut/adaptor right in place.
Unless there is something majorly wrong with the tank, this is a simple fix.
Just one headsup the (4) O rings for the four oil cooler lines look like they are still in the adaptors. No worries, but you really want some NEW O rings, PART#: ESR1594L. It's a mistake to reuse the old O rings.
Use a little ATF and Motor Oil to lube the O rings, and then put them on the lines first before you install the lines to the adaptors in the Rad. You will be back to HAPPY TOWN in no time!
themdg (04-04-2018)
#22
#24
#26
#29
Ok! Here is my report/follow up. I picked up the Radiator yesterday and am very pleased with the result. He fixed the leaks and painted it (to help with oxidation and rust, he says).
Put it back in, connected all the hoses (with new seals where applicable), refitted the fan, installed new belt, refitted the battery (had removed it for clearance), added new fluids, started her up. Took it for a drive for 20 mins to get the engine nice and hot. Looking great! We also changed the oil and installed the new therm while we were at it.
PS...Thanks OverRover for mentioning the O-rings. Two of them were still on there after the repair/paint. I removed all, and installed the new ones.
Only the expected oil leaks now. I see no power steering fluid on the ground (which has been the biggest one for a while) and no coolant on the ground. The shop that helped me diagnose it says it needs a new power steering gearbox, so maybe there will be some PS fluid there...but I'll wait and see.
Glad to have it back on the road. Thanks a ton for all the help and encouragement.
Next step is to go have the power steering and brakes power flushed. Shop says both are contaminated and that the brake fluid has some water in it (explaining the super soft brakes.)
Next project is valve cover gaskets and investigate where that other oil is dripping from.
Here are some photos:
Repaired / Repainted Radiator. Looks like it's in great shape now.
Repaired oil fixture. Notice the old O-ring still in place. Ha. Replaced with new one before install.
Front
Replaced steering lines.
New radiator installed w/ new upper/lower hoses.
New belt installed.
Back together!
Front
New belt installed.
Back together!
austinlandroverbill
02-16-2017 07:57 AM
austinlandroverbill
02-12-2017 10:19 PM
bosshogt
12-23-2011 10:24 AM
lipadj46
07-08-2009 07:41 PM
