front drive shaft
Old Apr 6, 2020 | 11:41 PM
Aaron Stephenson's Avatar
4th Gear
Default front drive shaft
i have read alot of threads on the front shafts breaking after lifting due to the angle and i was wondering why people say dont use the front shaft out of a d2 since it already has the double cardon joint built in? i know the swap requires the transfer case flange but other than that its an easy swap.
i also found adapters to run a spicer 1310 ujoint and i could swap the front shaft out to a 3/4 ton late 70s for front shaft which would give me 2in of extra length and much stronger. has anyone ever done this?
Old Apr 7, 2020 | 12:48 PM
Banzai Jimmy's Avatar
An original D2 front driveshaft does not have a greaseable double cardon joint. That'd be a big reason... and the main reason the D2 front driveshafts fail and take out the transmission.
Chrjones
Sep 10, 2016 09:12 PM
ProShaft-Justin
Jan 24, 2013 12:21 PM
Enrique5
Aug 26, 2012 07:59 PM
raul507
Oct 13, 2011 11:40 AM
98P38
Dec 28, 2008 01:30 AM
