Fuel Filter '96 Discovery
Old Jul 31, 2015 | 01:21 PM
96 WHITE's Avatar
7th Gear
Default Fuel Filter '96 Discovery
Where is the fuel filter on this car? I haven't changed it in the last 80-100K miles and I think it's about time.
Old Jul 31, 2015 | 03:30 PM
It is located on the frame above the right rear tire.
It, should be changed every 30,000 miles in the future.
Make sure to us plenty of penetrating fluid on the fittings before trying to remove the filter.
Old Jul 31, 2015 | 03:35 PM
fishEH's Avatar
If the fittings are super rusted you can just cut them out and install on of these.
http://smile.amazon.com/dp/B000C6MMD...=ICNR8CNQH8Q5Y
Old Jul 31, 2015 | 07:11 PM
antichrist's Avatar
I'd be cautious using that filter. I don't know what the Purolator specs are, but the Wix equivalent is 11 micron filtration whereas the Wix 33481 for the D1 has a 4 micron rating.
You can get replacement metal tubes with fittings for the OE filter at NAPA.
Old Jul 31, 2015 | 08:25 PM
fishEH's Avatar
Hmmm, it cross referenced as the same part as the one Atlantic British sells in their kit.
Old Aug 1, 2015 | 04:57 AM
antichrist's Avatar
It may be AB didn't really bother to check the specs, doesn't care, feels 11 micron is enough or the Wix doesn't filter as well as the Purolator. The last one would really surprise me if it were the case.
Or maybe the OE filter doesn't filter as well as the Wix.
Old Aug 1, 2015 | 09:23 AM
fishEH's Avatar
Yeah IDK. When I replaced the rusted seized filter on my '98 I just walked into Napa and grabbed a generic bar-b-ed filter, never thought about microns.....
It seemed to work fine but I see your point.
Old Aug 6, 2015 | 08:51 AM
96 WHITE's Avatar
7th Gear
Thank you gents. I will take care of replacing that bugger.
Old Aug 6, 2015 | 08:56 AM
Jagfixer's Avatar
Never had a problem with a WIX on anything I have or have owned.
me 2
Jul 5, 2012 07:40 AM
JumPeR04
Apr 7, 2011 09:52 PM
philmahr
Oct 25, 2010 04:43 PM
ryant06
Jul 25, 2010 11:35 PM
philmahr
Oct 26, 2006 04:58 PM
