Fuel gauge help!
Old Sep 29, 2024 | 07:06 PM
Trashpanda's Avatar
Default Fuel gauge help!
My fuel gauge doesn't work, shocker. It comes up just above the red and stops.
I've checked the float and it's attached.
its sending a good signal and i get the signal at the gauge cluster, i have 2 clusters and neither gauge will rise. What could the problem be?
At the cluster I was testing light green to green black, is that not right for the fuel gauge? Is there a mechanical replacement for the gauge?
Old Sep 29, 2024 | 11:19 PM
JohnZo's Avatar
Could be a bad ground in the signal path? That makes sense if the signal itself is OK. Just guessing, though, without reading the schematic.
Old Sep 30, 2024 | 07:55 AM
WaltNYC's Avatar
Here is my latest experience....
https://landroverforums.com/forum/di...48/#post904368
Old Dec 1, 2024 | 08:21 AM
Trashpanda's Avatar
the signal is ok, I'll have to check the grounds. When I test according to the rave manual I only get .5v and not the 5v that it says I should. With that in mind the sending unit on the pump tests poorly so I'll have to replace that before moving ahead.
Trashpanda's Avatar
Originally Posted by WaltNYC
Thanks!
Old Dec 1, 2024 | 07:32 PM
JohnZo's Avatar
If bad ground is the problem, the signal voltage can be different (i.e. lower) depending on where the multimeter ground probe is placed. If signal voltage goes to 5v (with full tank) when the meter ground is jumpered to battery negative, that indicates a bad ground path for the fuel gauge circuit. Then the bad ground location can be narrowed down by moving the ground jumper closer to the normal ground path. Hope this makes sense. In addition, if signal voltage stays (0.5 v in this case) low when the ground probe is connected to battery negative, then the signal circuit path is faulty.
Old Dec 1, 2024 | 07:37 PM
Trashpanda's Avatar
thanks, I've got a bit more testing to do it seems
MikeGroom
Dec 6, 2022 05:24 PM
MikeGroom
Dec 6, 2022 10:49 AM
Toran
Mar 16, 2016 10:03 AM
FlyingZebra34
Apr 6, 2013 09:38 AM
wheelgarage
Dec 3, 2011 04:59 PM
