Fuel Injector Installation - quick question
Old Aug 13, 2023 | 04:11 PM
DHTaylor's Avatar
Default Fuel Injector Installation - quick question
Installing refurbed fuel injectors. There is a clip that secures the top of the fuel injector into the fuel rail and ensures no movement up and down. There are actually two ridges that the clip can secure into. If you look at photo, there is a ridge just below the rubber O-ring at the top. Then, there is another ridge that also has the green plastic clip. Which of these ridges do I clip into? I originally thought it was the lower one with the green ring and the plastic ring ensured that the clip was tightly secured as well. But, it is nearly impossible for me to get this thing clipped in - I just broke two and still have a couple more to go.
I am now thinking I am supposed to clip the clips into the top ring closer to the O-ring. If so, what is the green plastic ring for?
Attached Thumbnails Fuel Injector Installation - quick question-img_2093.jpeg
Old Aug 14, 2023 | 09:28 PM
JohnZo's Avatar
The clips go at the top. The slots on the sides of the clips line up and grab the flared ends of the fuel rail bells. That way the injectors can't move away from the fuel rail. They only go on one way, injector clip bits down in the upper slot.
Maybe the green is color coding from the manufacturer of refurber. The Mustang 4-hole injectors in my 94 have an orange band.
keninnc
Aug 18, 2020 08:54 AM
04in719
Jul 14, 2017 12:23 PM
jpmiller
Jan 29, 2012 07:26 PM
davidlafrance
Apr 27, 2011 05:08 PM
