Fuel pressure?
Old May 29, 2012 | 07:32 PM
PSI at rail when primed? When cranking? Shouldn't FPR be hooked up and working?
Old May 29, 2012 | 07:38 PM
Sam95disco's Avatar
Yet to check PSI, gonna do it wednesday.
Old May 30, 2012 | 08:46 AM
Sam95disco's Avatar
Can the stepper motor(IACV) be tested to see if it works?
Old May 30, 2012 | 09:33 AM
ColoDisco's Avatar
I never came across a test on my rig.
Old May 30, 2012 | 11:45 AM
If you take out stepper and power up truck, it should move in/out on its own. Don't try to force it. Just clean with squirts of carb cleaner, and the bore it fits into. It is a computer controlled 200 step (or 180, depending on version) vacuum leak.
Old May 30, 2012 | 02:11 PM
Sam95disco's Avatar
No crank just turn key till power comes on?(fuel pump kicks on ect..)
Old May 30, 2012 | 02:54 PM
Sam95disco's Avatar
@#$%!!! It doesn't work Lets see if the junk yard has one I can nab. I'm not paying $140!
Old May 30, 2012 | 06:51 PM
Sam95disco's Avatar
Well it moves slow, has lots of carbon build up fug it.
Old May 30, 2012 | 07:07 PM
ColoDisco's Avatar
After you do a major job you need to recheck your steps on reassembly. I of all people know this (re: stall post). If it ran before you took it apart there is a good chance you have a simple problem.
Old May 30, 2012 | 09:03 PM
Sam95disco's Avatar
I know what did it in, I was cleaning the valve( I used gas, its cheaper and works better) but I should have removed the valve before hand.
