Fuel pressure?
Old Jun 1, 2012 | 09:19 PM
  #21
Sam95disco's Avatar
Found the valve at a salvage yard, they had 2 discos a 95 and a 96-98(didn't check yr) both had lots of parts left.
I got the valve for free, dude that helps you get parts off told me to put it in my pocket. He can't stand the guys at the counter lol.
I'll try it out Sat. I'm tired.
Old Jun 2, 2012 | 06:38 PM
  #22
Sam95disco's Avatar
Well no luck I think the injectors could be clogged, I sohould have never cleaned the intake system. @#$%!!! The cats and exhaust manifolds got hot. So there is combustion just not enough.
Old Jun 2, 2012 | 09:10 PM
  #23
How about peek at the attached and double check plug wires...
And take volt meter and measure for 12 volts at the brown/orange of any injector. The injector get + volts from fuse 7 under hood thru the engine load control relay. The ECU grounds injectors one by one to control fuel squirt.
File Type: pdf
Old Jun 3, 2012 | 12:09 PM
  #24
Sam95disco's Avatar
Am I looking at this right, the clip that holds down the distr cap is inbetween 8&1, with 8 to the left of the clip?
But on photo(rave) the vacuum unit is at top, my vacuum unit is on bottom Edit: just looked at book and vac is in right spot
Also one thing I did that the connections didn't have was dielectric grease, on all connections.
Valve I got at junk doesn't move.
see pic, screw driver points to distru cap clip.
atikovi
Mar 27, 2016 09:05 PM
JumPeR04
Apr 7, 2011 09:52 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
discomech
Jun 25, 2006 03:12 AM
