Fuel Pressure Regulator - Gasket Combo
Old Feb 15, 2019 | 06:11 PM
_ExpeditionMan's Avatar
Default Fuel Pressure Regulator - Gasket Combo
Hey guys,
Just wrapped up a headgasket job on my D1 and noticed a slight fuel smell from the truck. Turns out I have a small fuel (mostly vapor) leak from where the fuel pressure regulator meets the fuel rail. When I pulled this apart during the job there was an o-ring gasket and some sort of plastic spacer. During disassembly these two pieces came out separately. When I went to reassemble I attempted to place the o-ring around the spacer but that was too large. Seemed too tight sitting in front of the spacer but fit perfectly without the spacer at all. Long story short I assume it needs this plastic piece as the leak is definitely around the o-ring. SO does anyone have a diagram or can describe what the proper assembly of this looks like?
Old Feb 15, 2019 | 06:39 PM
OverRover's Avatar
IDK what year DI you have, but either a non-AEL or an AEL regulator mounts the same with the Oring after the spacer( there is a name for that piece).
Have a look.....
Old Feb 15, 2019 | 07:49 PM
Have a look.....
You're a lifesaver! Thanks I really need to update my signature. It's a 96 but pre-Ael (early build date). Dang I'm so disappointed that I missed this. I think I saved that spacer though.. fingers crossed.
Old Feb 15, 2019 | 08:14 PM
OverRover's Avatar
I hope you find that spacer (and that is what LR calls it) because you will need it in order for the o ring to seat properly.
I don't think I've seen the spacer sold separately, but you might try searching for the regulator which is ETC8494 to see what turns up.
Good Luck!
Old Feb 16, 2019 | 01:01 PM
Found it! Set it aside just in case. I'll swap it on and the truck should be good. Really appreciate you weighing in.
Old Feb 16, 2019 | 04:22 PM
OverRover's Avatar
Good on you for finding that bit! Once installed that will sort out the leak.
Just remember BEFORE your next repair to START HERE ( helps too) >
Old Feb 16, 2019 | 05:18 PM
ihscouts's Avatar
I loose my coffee mug all the time..... So how’s the head gasket experience going for you Expi?
Old May 2, 2019 | 11:42 PM
Sorry man I completely missed this comment! Trucks been my daily since doing the head gasket job. Runs pretty good now with a few exceptions. Sadly while I found the plastic spacer the o-ring had deteriorated beyond saving. Had a heck of a time trying to find the proper size to replace it but settled on a generic one from AutoZone. Truly I think it's slightly too small as I still smell a little gas vapor but
no more fluid leaks. If you know of how to find/where to buy the rubber o-ring I'd really owe you one.
Old May 2, 2019 | 11:56 PM
OverRover's Avatar
The o ring for the fuel pressure regulator is the same as the fuel injectors.
RTC5679 > https://www.roverparts.com/Parts/RTC5679
Old May 2, 2019 | 11:58 PM
Yes!!! Thank you that's a huge help. I'll definitely be ordering a few of those.
Drew c
Dec 9, 2018 03:54 PM
dmbenson
Jan 27, 2016 10:59 PM
demonlarry
Feb 27, 2013 10:11 PM
Akumal
Nov 6, 2012 03:04 PM
mac25dm
Sep 6, 2007 10:23 AM
