kick
Old May 1, 2019 | 10:37 PM
shawnsutton's Avatar
Default kick
Ok i am having issues with the new to me 95 disco,The temp guage,the speedo,the horn,the tach not working.I have looked all over this forum for GOOD advice in other threads and so far not finding much.I would greatly appreciate any HELP from anyone on these issues.Also where and what is the KICK?Where is the horn located?Thanks.
Old May 2, 2019 | 09:49 AM
WaltNYC's Avatar
speedo, temp, tach are all on the gauge cluster. perhaps check your fuses. Given the uncertain level of maintenance of prior owners, it is really difficult to pinpoint a 'silver bullet' solution.
Grab the workshop and electrical manuals from the google drive link in my signature. That is step #1 for sure.
Old May 2, 2019 | 09:56 PM
XCELLER8's Avatar
kick ?........do you mean the "kick" panel ??.......thats the plastic down by the footwells.....there are relays ( and corrosion) behind them, also a couple of ground posts that you should check....which may be part of your electrical problem
Old May 3, 2019 | 06:40 AM
fishEH's Avatar
Download the RAVE and review the ETM. Sounds like you have a single issue, fuse, power, or ground affecting your gauge cluster.
Your horn button is located on the steering wheel......by the "horn" symbol. 🤔 The actual horns are located behind the front grill.
How far along in your quest to unnecessarily remove wires from your truck are you?
Old May 3, 2019 | 10:53 AM
Ok i thank you all who replied i will check it out.I downloaded the links thank you much help on ordering parts.
Old May 3, 2019 | 01:00 PM
corrosion on the ground behind the kick.I wire brushed it then i took a new ground lead from battery to that ground and everything came on.dash lights,tach,speedo,fuel, dome, dummy lights,temp gauge and yes you guessed it. CHECK ENGINE LIGHT.Thanks all for the pointers.
Old May 3, 2019 | 03:09 PM
fishEH's Avatar
Panel. Kick P A N E L
Old May 3, 2019 | 09:34 PM
XCELLER8's Avatar
well thank ya, thankyaverymuch.............lol
Jsivey
Feb 19, 2017 07:10 AM
bmeier
Mar 15, 2015 04:40 PM
kipper1080
Dec 23, 2013 10:00 PM
bcbp
Jun 2, 2012 12:03 AM
AJBoardman
Nov 19, 2008 07:51 PM
