fuel pump harness
Well, prob is I dont think I was getting power to the pump. Truck wouldn't start, no pressure at the rail, but was getting spark. thats all the farther I got then had to go to work. By time I got home, truck fired right up. Pump and filter is only 2 weeks old. So I ordered a pump module/relay, and will see if it happens again.
I was just going to suggest a new fuel pump relay.
Had I known what the deal was I would have suggested that straight away.
They say you should replace it whenever you replace the pump, but I did not either and so far so good.
At almost $100, I wanted to make sure that's what was wrong before I went buying one,but unfortunatly didn't get a chance to. From what I've read, that's a pretty common symptom when they start going bad.
http://www.roverparts.com/Parts/YWB100820LG.cfm
theswede
Oct 29, 2015 01:05 AM
twilightcall
Mar 6, 2012 03:11 PM
