Fuel pump no power
Fuel pump no power
I have downloaded the RAVE but have found no wire schematics and found it slightly confusing as it covers so many years.
My 1997 Disco has the pump with advanced emissions and I am trying to confirm it ha son power and where my fuel pump relays are, I think mine is the module under hood as I do not see the relay with blue base on rh kick panel like RAVE talks about! I can troubleshoot most things no trouble but need test points and system components locations.
Please help if you can I installed a used pump a year ago so I thought it failed. right now it looks like no power to the pump but I am not sure I'm testing the right wires. Thanks for any help. I was not able to find specifics after a ton of reading online so here I am. Thank you for your time.
http://www.green-oval.com/data/lr/rave03.iso
It has the 1997 Export specific ETM.
You'll need to burn it to CD or install a free virtual CD drive like Daemon Tools Lite.
http://www.daemon-tools.cc/eng/products/dtLite
If you're still having problems figuring it out post back and I'll reply here so everyone has the info.
I can reply to any e mails with my phone if that works.
Thanks a bunch for everyones help so far.
aerialimage@comcast.net
In the RAVE download, find file "PDF". In that file, go to directory "L J" . In there is the D1 stuff, the wiring diagrams are in the files that start with "ETL", like "etlj970x". You have a body/interior manual, 3 electrical manuals (various years), workshop manual, owner's manual. Includes location photos, etc.
I have all the folders and pdf files but every page comes up blank?
OK, the old skool way -
relay is under right hand side kick panel, top row of relays, should have white/orange, white purple, and blue/purple wires coming out of it. And others.
Relay is fed by engine fuse box F6 (15 amp) and under dash satellite fuse strip F3 (10 amp).
Relay controls heat to the O2 sensors (white orange), evap on white/purple, and runs thru alarm immobilization "spider", then to inertia switch (push top of it to reset), then to fuel pump.
So be sure to check fuses and inertia switch. Power at the pump is on white/purple, pin 4 of the connector, 3 & 2 of that connector are ground.
Is there not a way Mac owners can run a virtual PC to allow pdfs, or some sort of conversion software?
Thanks to everyone for the help It was nice to hear the engine run again after sitting for a long time. Can't wait to be able to drive it again.
No trouble at all viewing those, Only problem was it all looked like start charge system only nothing referring to the fuel delivery system. Thank you very much for taking the time to post them for me though!
