Fuel pump no power
Heres some shop manual pages to make sense of it all. Sorry for low res, this web site won't let you upload more than a 2 meg PDF file (says 4 GB, but it's a typo), so have to send it in 72 DPI format, one step above an oil stain.
If you like what you see, perhaps you will figure out a way to get the RAVE for yourself on your Mac. Lessons are extra.
That looks like lots of great info. I will work my way through it as soon as I can and I'll post what I find. Thanks to everybody for the help!
fuel pump no power
2-3 weeks ago had cranking wont start, replaced CPS, and bench tested the fuel pump, started.
So ordered new pump (pump only) replaced, wont start, like there is no power to the pump. Pressed kill switch, switched yellow relay from one to another, nothing. gave up for today, planning to trace the wire harness from pump to wherever it goes, but should replace CPS again?
Please help.....
Please help.....
Would suggest you start a new thread in D2 area, so you will get more attention. Also, please review this post, it covers a D2 no crank problem, has a number of download documents, etc. https://landroverforums.com/forum/di...t=crank+sensor
Travelor
09-24-2015 06:11 PM
Sandman0306
12-15-2012 03:24 PM
JumPeR04
04-07-2011 09:52 PM
