fuel, spark or air? help please!
Old Aug 5, 2013 | 10:24 AM
Motorvated's Avatar
Default fuel, spark or air? help please!
Having issues on my 96 disco. *Wondering if yall can give me some help? Truck runs*smooth*at idle and when given some throttle, runs smooth through first gear and as soon as i shift into second, it bogs down. At first I thought*coilpack, so I replaced the entire $400 rail. I had a new alternator so I put that on and I'm still having the same issue. Truck sounds/acts like its not getting enough fuel or spark. Fuel pump or filter?*high side relay for fuel pump? Mechanic*tested the MAF and said it was all over the place, maybe its that? Whrn running, if I unplug the MAF, the motor bogs down for a second then goes back to normal. Any help would be awesome! !__________________
Old Aug 5, 2013 | 10:26 AM
What fault code numbers do you have?
Old Aug 5, 2013 | 10:59 AM
Stop throwing so many parts at it.
Buy a can of CRC made-for-MAF sensors, and spray it when the engine is cold and you have not turned the key for over six hours. A small spot inside heats to 350F, and does not like cold shock.
Fuel pressure test point on rail should read 32-34 psi. Fuel filter under right rear wheel arch. Changed in memory? Ever?
Fuel pressure regulator on driver side back corner of rail - six inch vac hose, any splits?
Plug wires ever changed? Plugs?
Old Aug 5, 2013 | 11:34 AM
archaeology_student's Avatar
Thumbs up
What Savannah Buzz said... start with the simple small things
MAF cleaner worked for me, as well as replacing plugs and wires Also, throw a new air filter at it
Old Aug 5, 2013 | 12:44 PM
Motorvated's Avatar
Trucks new to me, so I'm not sure about what's been changed. Luckiky the P/O thought it was the coilpacks and gave me the whole rail of new ones! $400 I didn't have to spend and tbe new alternator was free also. I sprayed the MAF with cleaner, it ran slightly better but still same issues. Also I can hear the relay for the fuel pump when I turn the truck on, but I dont hear it switch back off. Is there a low end and high end fuse?
Old Aug 5, 2013 | 12:45 PM
Motorvated's Avatar
Also, the P/O drove the truck on a 1000 mike expo and two days after started having these issues. If thst helps at all, I'm not sure
Psichotic
May 4, 2012 09:22 PM
ADDAM
Mar 10, 2012 12:26 PM
sawadeh
Jul 2, 2011 08:10 PM
musickjr
May 9, 2010 06:19 PM
NWDisco
Dec 13, 2006 03:11 AM
