Fuel temperature sensor
I have a 1996 Land Rover, has anyone had problems with or replaced the fuel temperature sensor? Mine bogs down & looses power & this seems to only happen during the warm/hot months, SO I kinda think maybe the fuel temp sensor might be the problem. Any suggestions?
You would get a check engine light specifically for the fuel temp sensor. The main culprit for hot restarts, warm temperature hesitation and poor fuel mileage is the coolant temp sensor for the ECU. There are two, one for your dash gauge, one for the computer. So my question is is the check engine light on? What's the code(s)?
Yes the check engine light comes on & it shows a misfire on 7 & 8 (I think that was it), I'll get the code & post it. Thank you!!! I started on this venture because I'm tired of mechanics PLAYING THE GUESSING GAME AT MY EXPENSE
. Wasn't told there would be a check engine light esp for the fuel temp sensor when a mechanic suggested it "was" the problem, after all the other things he has suggested to no avail.
CASE42
Nov 26, 2007 11:57 AM
