Fuses/Relays?
Old Oct 16, 2020 | 04:02 PM
cbwhitley's Avatar
Default Fuses/Relays?
Getting my 96’ back up and running after being parked a while. A lot of stuff doesn’t seem to work anymore...I know the Lucas wiring has its issues..but..All the fuses seem to be ok.. Here is a list of what no longer works. Where should I start?
AC - Is not engaging. Light in the Switch light does not come on
Fog lights. Light in the switch does not come on
Rear Wiper/Washer
Sunroofs
Pretty much everything on console around the speedo.
Old Oct 16, 2020 | 06:30 PM
stillruns's Avatar
Don’t even think about trying to engage the sunroofs. They will be your demise and water will pour in. Fog light bulbs are likely toast or housing is rusted. The rest I’ll leave for others.
Old Oct 17, 2020 | 08:39 PM
Eustace71's Avatar
Default Ac relay
Hi ive had the same problem with my ac sometimes it would work then nothing i brought a relay tester and found a faulty relay shaped it out and now seems to be working if you're car is lhd the relay is in the passenger side footwell behind the kick panel it is the top left relay hope this helps.
Old Aug 14, 2023 | 03:24 PM
FTL's Avatar
FTL
You say top left but you have the top "right" circled... Do you mean the top rear-most (aft)?
bwLR06
Jun 21, 2020 03:06 PM
green-lantern
Oct 4, 2015 07:32 AM
sdsilvere38
Aug 29, 2008 11:42 PM
guitarz32388
Jul 8, 2008 02:27 PM
twistdmetal
Feb 2, 2008 08:50 PM
