Getting my 96’ back up and running after being parked a while. A lot of stuff doesn’t seem to work anymore...I know the Lucas wiring has its issues..but..All the fuses seem to be ok.. Here is a list of what no longer works. Where should I start?
AC - Is not engaging. Light in the Switch light does not come on
Fog lights. Light in the switch does not come on
Rear Wiper/Washer
Sunroofs
Pretty much everything on console around the speedo.
Don’t even think about trying to engage the sunroofs. They will be your demise and water will pour in. Fog light bulbs are likely toast or housing is rusted. The rest I’ll leave for others.
Hi ive had the same problem with my ac sometimes it would work then nothing i brought a relay tester and found a faulty relay shaped it out and now seems to be working if you're car is lhd the relay is in the passenger side footwell behind the kick panel it is the top left relay hope this helps.
