gas tank problem
#22
yelah did you just call the dealer with your vin?
#23
#24
#26
I had the same issue. I looked underneath my 94 and next to the filler there is a smaller rubber hose that gets worn out and cracks right were it connects to a plastic fitting. I cut off the cracked rubber and tightened it up again. I also had the gas tank and fuel pump replaced 7 months ago curtousy of the recall and the tech said everything was cracked and leaking fuel.
aguison
11-18-2012 06:15 PM
moneypit37
06-21-2006 11:51 PM
