GEMS ECM Photos
Old Feb 26, 2013 | 09:48 PM
EricTyrrell's Avatar
Default GEMS ECM Photos
Took some photos of two GEMS ECMs. Maybe someone will find them interesting. ECM on the left is from an AEL 97. ECM on the right is from a 99. There are some obvious differences and many subtle differences. Most of the ICs actually have different part numbers between the two years.
Old Feb 27, 2013 | 07:07 AM
gprtech's Avatar
Few of the ICs have actual part numbers on them. The have date codes and Land Rover stock numbers.
The micros would have different numbers dues to different programming internally.
Old Feb 27, 2013 | 07:18 AM
And perhaps Lucas stock numbers. In competitve early production and prototype circuit boards not uncommon to find all the numbers wiped off with solvent to add extra steps to reverse engineering.
You can note that many components use surface mount technology, so hobbyist repair is limited. And one can imagine why a slug of sea water from the beach would have a bad impact on an un-sealed ECU for those that frolic in the surf.
Old Feb 27, 2013 | 07:36 AM
gprtech's Avatar
You're correct, I meant to say Lucas, not LR.
I bought an ECU/TPU combination off of Ebay, the ECU besides having corrosion on the housing, had a good quantity of sand in it.
Old Feb 27, 2013 | 07:55 AM
What you don't see is a clear sealant spray on the board for high humidity applications. Wonder if that is something we could add?
Old Feb 27, 2013 | 09:43 AM
gprtech's Avatar
It seems to be there on the one I disassembled.
tornado_735
Apr 18, 2009 06:07 PM
Jull
Feb 8, 2009 09:41 AM
tommia4
Feb 3, 2009 07:06 PM
hoberock
Jan 18, 2007 06:19 PM
riebs
Oct 7, 2006 02:15 PM
