GM Radiator Swap, 'Merica!
Old May 18, 2015 | 06:32 AM
  #61
TOM R's Avatar
So does the s10 read fit without mods to the hood? Broke my rad need to do something
Old May 18, 2015 | 10:09 AM
  #62
USNAVYORDNANCE's Avatar
No man. Not to my knowledge. The filler necks are the clearance issue. There is a GM rad that has a short, somewhat slanted fill neck but don't know what its from.
Old May 18, 2015 | 07:29 PM
  #63
Went to one of my suppliers earlier and measure out a 96-04 S10 Rad. No learance issues with that one. The one I tried had cooler ports on both sides too.
Old May 18, 2015 | 09:03 PM
  #64
TOM R's Avatar
So that should fit without cutting hood?
Old May 18, 2015 | 11:31 PM
  #65
Yup! Has the shorter slanted fill cap.
Old May 19, 2015 | 06:02 AM
  #66
nuclearw's Avatar
Only issue with the S10 rad's I saw was the lack of a heater return line...
Guess you're forcing me to do a writeup on my experience with this.........
So far a few issues with this setup (using the rad suggested originally)
1. Oil cooler and Tranny cooler are reversed not a huge deal for the tranny side as it has a large opening, and with just the fittings from the junkyard (cleaned out of course) can be used and fits perfect..
The Engine oil side, I recomend an external engine oil cooler if you're going this route.. the side for the engine oil is almost 1/2 the size it should be and restricting oil flow is a bad thing in any engine, but worse than most for these.
I'm looking at one of these for ~50$
Amazon.com: Hayden Automotive 1215 Heavy Duty Oil Cooler: Automotive Amazon.com: Hayden Automotive 1215 Heavy Duty Oil Cooler: Automotive
Need to do a bit more research on the oil cooler, to get my truck back on the road I grabbed some brass barbs and reduced the line size before the radiator... I'm taking it easy on the truck till I get to put the real oil cooler in place.
Also, S-10 rad is a 15in core not 17in so should fit in the space the original occupied.
Cutting the clips off mine (i'll post pics for this too... just don't have time till later today) the 17in core sticks up a fair bit,
The lower radiator hose is up against something on the frame just behind the radiator. I need to see if I can cut this off, it looks like a loop is attached to the one on the drivers side (recovery point??), potentially something to cut off but for now I added some extra hose in between to keep it from rubbing through.
the size of the core is the actual mesh, and doesn't account for the 1/2in or so at the top and bottom for support (wish I realized this heh, also wish I just measured for myself to begin with. .. lol)
I don't mind the engine oil cooler addon, but if you are in a colder area it would pay to have a thermostat for the oil to let it get up to temperature.. somethin like
Amazon.com: Derale 15719 Fluid Control Thermostat Kit: Automotive
I'll be back later with a better writeup, and some pics...
Old May 19, 2015 | 11:47 AM
  #67
Yeah, I'm not really into the write-ups. Sounds like a job for you nuke.
I did cut that piece of steel off from the frame by the lower rad hose. As for heater hookup, just use a t-fitting on the lower hose to supply the coolant. I'm in sunny SD so need for a heater. The coolers on my rad are working as they should, restricted and all! Hottest temp I've seen lately is 187*....
Old May 19, 2015 | 09:00 PM
  #68
TOM R's Avatar
How bout this early s10?
New Radiator s 10 Blazer S10 Pickup Jimmy S15 Chevy Aluminum Core Plastic Tank | eBay
Old May 20, 2015 | 06:37 AM
  #69
nuclearw's Avatar
Tom, that looks good. Only concern I have is routing of that heater return line through the oil cooler lines (not an issue if you go with an aftermarket cooler) well and possibly the height of the filler neck, but your dropping two inches from the one I used so it may be close but should work
the later ones can work too if you get one of the rad feed hoses that has a inlet for the heater potentially..
If you're in a colder part of the country then the heat re-circulation will help the engine get up to temp earlier.
The nice thing about the ones with the heater return to radiator, it will help you drain the air out of the system easier.
edit:
I also forgot, you need to plug the return line for the throttle body heater. I will be putting a brass T in to allow this to return to the heater line/rad at some point...
Old May 26, 2015 | 07:00 AM
  #70
TOM R's Avatar
Thought about this a lot last night and came up with Chevy caprice , not sure about dual oil coolers , but v8 should be short neck, and has the heater return
