Greasing Swivels
Old Jan 10, 2011 | 08:53 AM
thehun's Avatar
Default Greasing Swivels
Am I doing something wrong, or its just not a whole lot of fluid goes into when your filling it...i might get 4 bumps of grease in it before it shows full...thanks guys...i do not have a drainable swivel housing
Old Jan 10, 2011 | 09:24 AM
Long Haul's Avatar
Are they empty and your refilling them? How are you telling that they are full? I use 90/140w gear oil and they take about 3/4 qt per side.
Old Jan 10, 2011 | 09:27 AM
kenk's Avatar
Are you're wheels pointed straight ahead when filling? The have to be turned inward to fill better. When straight ahead, the fill hole is almost blocked by the swivel. For drivers side, turn the steering wheel right, pass. side turn left. Grease will go in alot easier then.
Old Jan 10, 2011 | 01:24 PM
thehun's Avatar
I tried straight. I do not have a drain on my swivels.
When you take the fill plug out. Does the swivel has a hole you pump into? Because I can't see one if there is
Old Jan 10, 2011 | 01:34 PM
thehun's Avatar
Nevemind so I just need to have full lock to put grease in there
Old Jan 11, 2011 | 09:49 AM
How about your wheel bearing, have you removed, cleaned and or replaced them, you should both front and rear.
Old Jan 11, 2011 | 02:16 PM
thehun's Avatar
PO replaced them about a month before i got the rover Mechanically this thing has been maintained well...just not on the outside...it was never waxed
Started right up at 0 degree weather
Old Jan 13, 2011 | 05:33 PM
thehun's Avatar
thanks..much appreciate it..it took 20 min to do everything...it took 3/4 quart each side...i put in 85w140
geek_IM
Jun 15, 2014 08:56 AM
greg409
Sep 17, 2010 03:15 PM
texmanmoore
Apr 29, 2008 01:23 PM
texmanmoore
Mar 10, 2008 09:06 PM
Newbie
Nov 1, 2007 11:06 AM
