Great... Check Engine Light is on.
Old Dec 23, 2010 | 09:26 AM
  #21
Dezert Rover's Avatar
....no light yet since clearing the codes yesterday.
Old Dec 23, 2010 | 09:43 AM
  #22
ngarover's Avatar
first thing with those codes I do is replace plugs and wires.
Old Dec 23, 2010 | 11:06 AM
  #23
groundandpound's Avatar
Default Ed Zachery
Exactly.
Identical codes - had the cheap wires from previous owner.
Bought the 8MM and changed plugs - no codes for over 6 months.
Old Dec 24, 2010 | 09:20 AM
  #24
sideburns's Avatar
If you want to fix it do a valve job, carbon builds up on the valve stems due to close tolerences from the factory. I have had to do them on cars with as little as 9k miles on the odometer. Make sure you use original Champion saprk plugs, nothiing else.
Old Dec 24, 2010 | 09:27 AM
  #25
Rover Chris's Avatar
Why would you do (what many would consider) a major job like that on a vehicle that has less than 9K? my average mileage is over 10K a year so for me that vehicle would be less than a year old?
Old Dec 26, 2010 | 05:59 PM
  #26
sideburns's Avatar
Yes I understand what your saying ,but the valve guides from the factory are too small, if you get a little carbon build up on the stem it will cause misfires that no fuel additive or injection service will correct, you have to pull the heads and do a 2 step ream out to enlarge the guide in all the exhaust valve, believe me I've been there done it.
Old Dec 27, 2010 | 11:25 PM
  #27
Arm and hammer's Avatar
How is your muffler ? If your muffler between engine and oxygen sensor have crack somewhere or your gasket between exhaust manifold and exhaust pipe is blown , oxygen sensor will read that extra air coming in the muffler and tell mama ( ecu ) mama may call it misfire.
Perfectphoto
May 31, 2019 08:27 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
