Have no steering on My Disco I ???
Old Jan 18, 2012 | 10:30 AM
srfnsno99's Avatar
Unhappy Have no steering on My Disco I ???
Any help would be appreciated..Thank you!!!
I was parked in the city yesterday. It was a tight squeeze....my truck has always had an inch of play on both sides. So I was turning the wheel a multiple of times without moving the truck..ouch..I know. Had no choice. the lst turn to the steering wheel...my steering wheel all of a sudden had now 9inches of movemnet on both sides before the wheels would even move. Now I was out in the street and made a U-turn and then lost complete use of the steering wheel and now the steering wheels goes round and round and the wheels do not move. So.....I am assuming the Steering Gear Box is gone????
Any help would be great..
Thank you
Old Jan 18, 2012 | 11:52 AM
See attached from RAVE shop manual, under steering. There is a big nut on top of the steering box that can be adjusted. Since we are talking about a field repair, rather than perfection at a shop, you might want the adjustment on the steering box to see if you have anything left. Many times a lot of slack can be removed from the system. If so, this may give you time to make perfect adjustments or replace / rebuild the steering box. In a rare case, you could also have a missing pin frm the steering linkage.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 18, 2012 | 11:57 AM
fishEH's Avatar
I'm assuming your Power Steering(actually tranny fluid) is full?
Old Jan 18, 2012 | 02:51 PM
Danny Lee 97 Disco's Avatar
Did you bother raising the hood and or getting underneath it to look for the obvious?
Old Jan 18, 2012 | 08:12 PM
If the steering wheel just spins in a circle then something broke.
Here is a diagram of the steering components, start looking for whats broke.
Land Rover Discovery I Steering Parts Available from RoversNorth.com
Old Jan 18, 2012 | 08:17 PM
honda50r's Avatar
Like Danny Lee, you just ignored it when it happened? Then attempted a u-turn? Linkage
Old Jan 18, 2012 | 09:20 PM
pimnmike's Avatar
Check you gear teeth from your steering shaft into your gearbox. I had the same problem. Best of luck.
Old Jan 19, 2012 | 12:41 AM
EricTyrrell's Avatar
Disco in the city is like a Prius in the outback.
Old Jan 19, 2012 | 06:28 AM
slanginsanjuan's Avatar
that's insane.
clang
Nov 12, 2015 12:17 PM
chriss2s
May 29, 2012 06:51 AM
nelsontod
May 18, 2012 12:20 PM
USMC_Denver
Apr 21, 2009 05:58 PM
