Headlight issues
The DI has 'city lights' that a dim lights akin to parking lights. They are different than your main headlights although they are in the same housing.
I suspect your city lights are working but your headlamp is not. I had the same problem. Turned out to be a shorted pig-tail connector. Easy fix by splicing in a new one and can be obtained at your local Napa store.
More info can be found here....
https://landroverforums.com/forum/di...e-power-40213/
You can also use the opportunity to upgrade your headlamp wiring by installing two relays, one for the the low beam and one for the high, both main feeds (10ga) supplied from the battery and the relays controlled by the existing high and low beam circuits. Then run 12ga from relays to the headlamps and upgrade the headlamp grounds to 12ga.
This will let you have full voltage to your headlamps (minimal volt drop).
gmfain
02-16-2015 09:37 AM
