Headlight issues
Old Nov 28, 2011 | 05:34 AM
collin Barrows's Avatar
Default Headlight issues
Yesterday I did a couple moderate trails, drove home and noticed that my right headlight was dim and it was still dim when I turned on the high beams. My headlight bulbs are sylvania and where replaced in February.
Thanks Collin
Old Nov 28, 2011 | 06:16 AM
WaltNYC's Avatar
The DI has 'city lights' that a dim lights akin to parking lights. They are different than your main headlights although they are in the same housing.
I suspect your city lights are working but your headlamp is not. I had the same problem. Turned out to be a shorted pig-tail connector. Easy fix by splicing in a new one and can be obtained at your local Napa store.
More info can be found here....
https://landroverforums.com/forum/di...e-power-40213/
Old Nov 28, 2011 | 06:36 AM
antichrist's Avatar
You can also use the opportunity to upgrade your headlamp wiring by installing two relays, one for the the low beam and one for the high, both main feeds (10ga) supplied from the battery and the relays controlled by the existing high and low beam circuits. Then run 12ga from relays to the headlamps and upgrade the headlamp grounds to 12ga.
This will let you have full voltage to your headlamps (minimal volt drop).
Old Nov 28, 2011 | 06:48 AM
CB - see the smaller hole on the lower right of the main lamp? That's the "city light" spot, has second twist connector on the backside.
Old Nov 28, 2011 | 03:45 PM
Thanks for the advice! I'll report back after I'm done.
What color is your city lights? My city lights are green, is that normal?
Attached Thumbnails Headlight issues-land-rover.jpg   Headlight issues-photo0405.jpg
Old Nov 28, 2011 | 04:09 PM
DiscoBlanco's Avatar
I suspect the green lights were an "upgrade" from the previous owner... Are there any neon lights on the under carriage?
Old Nov 28, 2011 | 04:41 PM
ValveCoverGasket's Avatar
im sure thats aftermarket.
Old Nov 28, 2011 | 05:07 PM
I kinda figured, but my disco was 1 of 10 that came from Britain, (yes I know they all do) for the 1996 Olympics, so I'm not sure if its OEM or after market, but most likely is after market
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
roverdrj
Feb 6, 2014 09:32 PM
Disco03
Dec 1, 2008 08:08 PM
igriego
Jun 25, 2005 08:48 PM
